fbrc8-erin 316
It also looks like the cable cover is still on. You might have a little more luck with screwing it all back together if you remove the cable cover so you can get at the motor more easily. It's held on by 1 screw below the feeder motor on the back panel, and one screw below the X motor on the left panel. The screws are identified here on the screw diagram as the Left Cover screws: https://fbrc8.zendesk.com/hc/en-us/articles/206579613-Where-Is-the-Screw-I-Need-UM2-and-UM2-Extended-
Waternut13134 1
The black piece that is attached to the printer,Take it off and assemble it with the piece you have to the left of the picture. (Basically you want this all assembled). Now as 1 piece put the screws through the holes and attach it to the stepper motor. It will make it a whole lot easier if you take the white metal cover that covers the stepper motor so you can align the screws better.
Edit: after looking at the pieces I believe you put the parts in the wrong case. Try putting them in the case that is currently connected to the printer.
Edited by GuestLink to post
