Cura 2.3.1 temperature setting
fma
Posted · Cura 2.3.1 temperature setting
According to embedded doc (tip), setting the temperature to 0 allows to set it manually. So, it should not be set by Cura.
It works fine for the bed temperature, but not for extruder temperature: if it removes the M104 Sxxx line, the M109 S0 line remains.
This line should be removed too...
