Only first item gets a skirt (one at a time print settings), all items need one!
Posted · Only first item gets a skirt (one at a time print settings), all items need one!
Hi guys,
Every item I print in ABS with a skirt turns out beautifully, the items without skirt are all messed up on the bottom layers. Whenever I try to print multiple objects with skirt in one at a time mode, only the first one gets its skirt althought the print preview does show a skirt for all items. Does anyone know how to adjust settings so every item printed this way gets a skirt? Or is this a bug? I would appreciate a solution soon because my time to market should be drastically higher; I can only print one item at nighttime now.
Settings:
Cura 2.3.0
Nozzle 0,4mm
Fine presets used
ABS
One at a time, 4 items
    yes it is a bug, reported it already and hope for a solution in the next release!
    Use it a lot also, the workaround is to add more skirt lines to get the material going before the actual object starts.
