Ultimaker PVA not sticking to BuildTak.
RayvenMaker
Posted · Ultimaker PVA not sticking to BuildTak.
Just posting a new topic here. Ok, I got the BuildTak, and the nozzle doesn't melt through it. score The only thing is, I can't seem to get PVA to stick. I haven't tried to put glue on the BuildTak (that just seems wrong), so I'm coming here for advice. What should I do? Has anyone else had this problem? Thanks.
Make On!
RayvenMaker
    Posted (edited) · Ultimaker PVA not sticking to BuildTak.
    Under build plate adhesion select type as Brim. Use PLA from core 1 instead of PVA from core 2 for adhesion.
    I tried that at first... PVA still prints inside the brim if I do that when I'm printing support. What about a raft of the first material? Or, what about this—what if there was a setting where everything on the first layer was a certain material (e.g. ABS), and then everything else after that would proceed as normal. Then, if you had a glass build plate, you could print the first layer in entirely PVA to make sure it sticks, then print whatever else you want after that. SandervG, what do you think?
