WIFI PROBLEM
droneking
Posted · WIFI PROBLEM
Just got the UM3 2 days ago and after 2nd print the um3 is no longer connected via wifi anymore...tried to reconnect and no luck. Tried to use usb stick supplied since i couldnt transfer file vis wifi and the usb stick does not open to allow me to choose file when inserted into um3. Rather disappointed $3500 later and only on its 2nd day. Tried rebooting printer and mac pc....any suggestions or help please!...Peter
    • 1 month later...
    When you boot the printer it doesn't connect to the network? You normally see it's ip adress
    To print with the usb key you need to go to the print menu and then you should be able to select the gcode you created and copied from your computer
