I've had these green artefacts in my print when using white PLA - my problem was a leak from the nozzle. Suggest you make sure the nozzle is tightened while hot to ensure a proper tight fit.
Thanks for your replies! It turned out it was that the nozzle was not screwed on tight enough, as you said Chris
Cheers
geert_2 558
I have seen brown, grey and black debris, but no green yet. These were all from burnt material inside the nozzle. If you do an atomic pull (also named "cold pull"), is any dirt green too?
It could be that some of the white additives decompose, or react with the decomposing PLA and turn green when too hot? What you could try is keep an end of filament in a flame until it melts and starts burning, and see what color that gets?
