thanks peggyb, let me try what you have advised, the printer is all custom made, Fisnar, and we have programmed it for printing. i know there is no issue with the printer , it has to be with the Cura software Ver (2.3.1), and maybe like you said, try different sizes of the box.
Thanks peggyb. i figured it out, some issue with the skirt- raft, and of course the dimension of the box, which was way too small. thanks peggyb.
is it about inches en millimeters? Use the scale function to set it right
peggyb 169
this looks like you have a raft enabled. Tab 'Build Plate Adhesion' there is the choice of skirt-brim-raft.
And your box is very small, note that the nozzle is 0.4 mm and needs to go around your model. What printer do you have? Can you use a 0.25 nozzle?
