I have the same problem with Cura 12.12A on my Lenovo Thinkpad laptop (Windows7-SP1). It shows just a few pixels of the object. I went back to Cura 12.08 which works fine.
Cura 12.12 is ok on my Ubuntu desktop machine.
Johan
Johan
Just installed a previous version of Cura, but the problem still remains.
I've added a print screen, so that you can see the problem
http://img6.imageshack.us/img6/4434/printscreenph.jpg
The computer I'm using is an Asus EEEPC 1005PEG
R. Couto
I've been tracking down this problem and it's related to the video card drivers, I'm trying to fix it, but it's not easy. You can try installing the 13.01 version, it's under the testing releases on the download site.
Hi Daid,
Thanks for your reply, I've just installed the 13.01 version, and sadly the problem is the same :/
Do you know any alternative to run this thing?
Thanks
illuminarti 18
Have you tried different models? I had this happen with some stl files before now, although in general it works fine. If its just certain ones, then perhaps trying to repair the stl file in Netfabb might help?
