Cura 2.4 Print Seq. "One at a time" retraction between objects issue
SunshineChowder
Posted · Cura 2.4 Print Seq. "One at a time" retraction between objects issue
We can print multiple objects fine with the "All at Once" setting. The first layer looks great and everything is fine. I prefer the quality of printing each object one at a time. When I change and use the "One at a time" setting it seems to do a larger or double retraction so when it starts to print the second object there is no filament for a while. It does the same thing with or without a brim.
Here is a video of the transition to the new object. You can see the filament doesn't make it back to the nozzle until it makes it 1/2 way through the first layer.
Greg
    Wow, they didn't change that in 2.4? That is really disappointing.....
    To help you in the meantime you can set the skirt lines to a higher number and hope they are going to fix this soon.... I really miss this too!
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 11 replies
