Daid 306
Cura 13.01 has a bug in the default "nextObject.gcode" (you can edit this on the start/end-code tab)
I only figured it out yesterday.
The line:
G1 X{object_center_x} Y{object_center_x} F{travel_speed}
Should be:
G1 X{object_center_x} Y{object_center_y} F{travel_speed}
See the subtle difference?
