Thanks for the quick response.
The temp is 240C for ABS so it's fine.
Yes the wall thickness is like 1.28 with 100% flow.
But even att 100% flow the top layer is not good, under extruding.
What other parameters is there in Cura for calibrating wall thickness
if not flow?
Labern 775
Is the wall thickness to wide if set to 100% flow? This maybe because the filament is getting to hot, try reducing the temp instead. You shouldn't adjust flow to correct any problems.
