No I haven't experienced this.
Do your atomic pulls. I don't think this would be the cause and I never do them on mine but it will eliminate it from the back of your mind.
CURA 2.4 beta has heaps of profile changes to previous versions so I would revert back to the version you used when you first got you're UM3.
You may have to do a fresh install by deleting the CURA folders that hold all the saved profiles to remove any possible changes that may be effecting your issues.
I did a cold pull and it came out remarkably clean. I guess there is something to be said for the UM3's handling of the print core! It made no difference as expected.
I had been coming to the conclusion that I might have an issue with the Beta and had just done a test print that goes at least part way to proving that point. I am going to take your recommendation and revert back to 2.3 (clean). Are there folders hidden somewhere that I need to wipe?
Thanks, Will
Labern 772
