Sequence imprimanter
Posted · Sequence imprimanter
Bonsoir
J'aurai une question comme imprimer en sequenciel c'est a dire une pièce après l'autre (si plusieurs pièce evidament) sous cura 2.4 avec une um3
Il a l'option mais elle ne s'active pas
Merci
    Posted (edited) · Sequence imprimanter
    c'est compliqué
    A potential untested workaround is to add a UM3 definition to Cura that forces it to regard the UM3 as a single extrusion printer. You won't have dual extrusion, but you will have One at a Time printing. Here is such a definition:
    https://gist.github.com/fieldOfView/bde7189087721451784865a28f3fc2c1
    Place it inside the "definitions" folder either in your Cura application folder or in the "definitions" folder inside your configuration folder. You would then create a new printer inside Cura and pick the "Ultimaker 3 single extrusion" printer definition. You can have both an "Ultimaker 3" and an "Ultimaker 3 single extrusion" printer connected to the same physical printer in Cura, so you can then choose between single extrusion prints that allow One at a Time, and dual extrusion prints that don't.
    (My french is not great)
    (edit: and neither are my copy/paste skills)
    Thank you for your reply could you give me your link because this one does not work error 404
    For the reponce in English thanks to goolge translation
    I got ERROR 404 on this link.
    ultimaker3_single.def.json
    Sorry for the broken link, and thanks @tinkergnome for posting the correct one. I have edited my post above.
    Note that I don't have a UM3 myself, so I have not tested the definition. If you try it please report if it works.
    Tank you
    I'll try this
    A first observation: the default UM3 profiles have the prime tower enabled, and it can not be disabled, because this setting is hidden for single extruder machines... :)
    I don't know, if this can be overridden by the machine settings.
    The workaround is: create a profile with disabled prime tower (while the "normal" UM3 is the current printer).
    Good catch. I have updated my gist with a *much* simpler version that also fixes this issue.
    Cool stuff guys thanks for helping :)
