Since the virtual COM ports show up in the Device Manager, your software should also be able to find them. All you have to do is add all available ports to a combo box and let the user select which one to use. The Black Widow is based on the MKS 1.3 - 1.4 board, which is Arduino based. I will send a message to Tevo to see if they will work with you.
nallath 1,098
2.4 and 15.04 should run side by side without issues.
As said before; We can't test USB printing for machines that we don't have. So if people want this fixed, they are free to send me a 3D printer
