Cura won't open
Lmil0315
Posted · Cura won't open
IMG_20170227_212030.thumb.jpg.1ade96e6b4de9ea60a710efd1f4cc5a4.jpg[/media]
I get this error message when I try to open Cura 2.4. It works of launched after installation but then one I close it out this happens and won't go away until I end the process in task manager. Have to reinstall cura for it to work again. Starts all over if I exit, any recommendations? Cura 2.3 worked until I installed cuts 2.4 then it also stated doing it. I'm assuming it has something to do with the sd card. Tried with it both in and out of reader. Thanks!
    You can try to remove the Cura software, and then go to the program files on your windows disk. There you can remove the Cura folder and try to reinstall Cura...
    I have the same problem:
    https://ultimaker.com/en/community/38971-cant-run-cura-240?page=1&sort=#reply-172850
    The only suggestion I've received so far is to rename the drive letter of the SD Card. I'm not about to mess with my system configuration for broken software. But I have not found any other solution. So, for now, I'm using S3D...
