Bug with UM2+ material profiles?
BIKBart
Posted · Bug with UM2+ material profiles?
Hi Guys,
Searched on the forums but did not find a direct answer to my problem. When I copy the Materials.txt file from the printer to the SD card and edit the file on my pc, newly created material profiles have issues with the retraction length. It is set to something like 254.00 mm when I import the material profiles back into the printer, instead of the value I set it to on my pc. When I edit the parameter on the printer itself, it's saved as it is supposed to.
Anyone else experienced the problem and is there a solution available?
