No, the video is actually quite right.
It turns out that for better results, you need to change more settings in the slicing parameters than can be set on the printer. That is why for the UM2+ you set the material both in Cura and on the printer.
What settings are you saying change when you change the material in Cura for an UM2+?
"The Ultimaker 2 (Go/Extended) and Ultimaker 2+ (Extended) use UltiGCode. This means that the material settings are not in the gcode itself, but stored on the machine." https://ultimaker.com/en/resources/20982-custom-materials-ultimaker2-plus
ahoeben 1,723
