oh my gosh. that was it! in layer view it shows up exactly like it was printed. THANK YOU SO MUCH! may this be the cause of the skipping as in the video also?
I didn't spot any skipping in the video. When you talk about skipping, I think of the case where the filament can't exit the nozzle because of a partial clog or other problems in the bowden tube. The extruder motor then skips back because it can't push the filament further.
Apologies then. I'm not sure what the correct word would be. In the 2nd video, when it starts printing with the 2nd head, it moves like as it would slip. the head moves slowly and then it's like it slips on ice and moves fast to the next point. It shows best at 0:45 I think. Also, the beeping, is it a bad thing? I assumed it beeps when it collides with something or the motor faces heavy resistance
This is ok, no need to worry. The fast moves of the head are called "travel moves". You see them in the Cura layer view as blue lines. That's when the print head needs to go to the next area and print there.
The beeping is a retraction move. This is no problem either. Retractions are performed mostly in combination with travel moves in order to avoid oozed filament to get in the way and stick to the printed object.
There are tons of slicing parameters in Cura which can influence these moves. But it is recommended to stick with the defaults until you feel comfortable with the printer.
When you are ready, access the settings in Cura and enable some (or all) slicing options. Then softly say "OMG so many!" and then faint
Okay.I was having doubts about my calibration. It's just that sometimes the whole frame shackes and it scared me. Thank you!
Nicolinux 288
it could be that the letters are too thin and Cura "slices them away". In Cura select the "layer view" on the left side (the button with the eye on it).
There you can scroll through layers and see what will be printed. This view is super useful - you should always check it before a print.
