Posted (edited) · Sizeable Window
Just a thought... it would be really great if the main Cura window were sizable. Running Cura 2.4.0 under Ubuntu 16.04 LTS, I find that it is necessary to auto hide the top and bottom panels to be able to see all of the Cura window. If I don't hide those bars, then I am unable to see the [save to File] button, the object dimensions, the print time and the filament usage. If I were to be able to size the Cura window down a bit like I can every other program I run, I wouldn't have this trouble. And I really hate autohiding bars.
www.RobotsAndComputers.com/temp/CuraScreenshot.png
-=[ edit ]=-
I had better be more specific. I am able to resize the window left to right, but not up and down.
    Posted · Sizeable Window
    Because otherwise things would not fit nicely. Fortunately the minimum size is fairly easy to alter:
    * Inside the Cura folder, find /resources/themes/cura/theme.json.
    * In that file, find "window_minimum_size".
    * The numbers after that are the minimum size in pixels, divided by a dpi-related number. Change them to eg [70, 40].
    * Restart Cura
