Yeah, 768 is the largest I can go on my laptop. Why is the minimum size necessary?
Because otherwise things would not fit nicely. Fortunately the minimum size is fairly easy to alter:
* Inside the Cura folder, find /resources/themes/cura/theme.json.
* In that file, find "window_minimum_size".
* The numbers after that are the minimum size in pixels, divided by a dpi-related number. Change them to eg [70, 40].
* Restart Cura
Thank you. That worked - and looks - perfect!
ahoeben 1,986
The window is already resizable in both directions, but it has a minimum height which apparently it higher than your screen height.
