Ultimaker app
Tiger91
Posted · Ultimaker app
Hi everyone,
I have a nexus 5 and would like to be able to print/view prints from my phone.
Unfortunately, I am not able to connect to the home network I use because the N5 is just bad like that.
Has anyone had this trouble and found workarounds? I get authentication problem when I try to connect?
Of course, if there was a way to monitor the print from my email account, or something else that would be great to know.
Thanks.
    Posted (edited) · Ultimaker app
    Is it just bad because of the wifi connection on the phone?
    I connect when i'm out of the house by login to the home network through VPN, on a samsung S7, works fine.  The VPN setup depends on your home router. I'n my case (fritzbox) it was super easy to setup. Look into the manual of your router how to do it.
