First, cura 2.4 is a totally new program, build from ground up, don't use any 15xx files, plugins etc, will not work.
Then, for the sake of curiosity (only own Ultimakers) I had a look at the PLAY setup.
I see there is at least a printer definition available, so that's nice, but it does not seem a very refined one...
I see by default all visibility settings are turned on, even the ones you definitely don't need, like for dual extrusion, so you probably want to clean this up.
Also the standard profiles are weird;
"normal" is 0.2 and "low" is 0.15 - does not make any sense...
If you want to change the base setup of the machine you'll find the machine definition here; C:\Program Files\Cura 2.4\resources\definitions
And most of the base settings can be changed in a menu in the machine settings.
I guess your quickest solution would be to get some profiles and a project file from someone who already tweaked cura for the PLAY (is there no printrbot forum?) else you'll just have to do some trial and error yourself....
I'm excited because I've personally produced this showcase event, so if you are curious what else I'm up to nowadays, come check it out and say hi in the chat! It would mean a lot!
ultiarjan 1,215
Edited by GuestLink to post
