Getting PVA to stick to build plate with Simplify 3D
Tiger91
Posted · Getting PVA to stick to build plate with Simplify 3D
I downloaded Cura to use with my new UM3, and it is able to print PVA support that sticks to the bed no problem. However, I love S3D because it is much faster than Cura (9 hours vs 3 for one print.
My problem is that when I try to use S3D for PVA, it always tends to lift from the build plate no matter how much glue/hairspray I use. I'm able to get the regular PLA to stick though.
Does anyone know the best settings for S3D so it can successfully print PVA on the UM3?
    • 5 weeks later...
    Hi, and sorry for the late answer. I don't think it is realistic to expect such a dramatic speed increase in S3D over Cura. Have you compared their print settings with the print profile you selected in Cura?
    As for PVA - I don't have experience with S3D and PVA - sorry.
        • 27 replies
