Actually yes, it looks like print core 2 keeps its standby temperature although it needs to print. I noticed that print core 1 immediately reaches 205°C but print core 2 is stacked to 100°.
Did I forget to do something ? It is a known problem ?
Well, this is odd... I just started the printing again after doing a complete reset of the printer, and it seems that it was enough to solve the problem. Print core 2 now reaches its print temperature so PVA material can come out the nozzle.
Good to know.
Strange, but if it works then let's say it's a slicing error maybe? Or did the print head actually put the print core down and wait for it to heat?
DidierKlein 729
Hi and welcome,
The 100°c looks like the standby temperature when the core is not used.
Do you mean that it should be printing and that the printer hangs because it can't heat? Or is the temp staying at 100°c because the 2nd core is not used?
