Ultimaker 3 Web-api
maphstra
Posted · Ultimaker 3 Web-api
Hi, I know the Ultimaker 3 has a web-api you can use, e.g http://ultimaker.ip/api/v1/print_job or http://ultimaker.ip:8080/?action=stream.
However, i'm struggling to find an overview or some sort of documentation for this API, or the different htmls you can visit. Does such an overview exist? Am I just bad at googling?
Also, is it possible to use this api to upload gcode-files directly without using Cura?
Thanks.
    As of firmware 3.6, you can also find documentation on the API on the printer itself.
    At http://[ip]/docs/api
    As soon as this release is turned into stable, I will update those posts to reflect this.
    Thanks for the help! Those blog posts are helpful yes.
    Trying to access the page you mentioned Daid, i'm transferred to the start.html-page which I never can complete. It doesn't let me pass the 'name your printer' page. That box doesn't accept any name I type into it.
    The start.html isn't related to the documentation (it is the wifi setup). If you don't end up at the documentation then your firmware is most likely older then required for this documentation.
