Posted · Layflat Feature. Bug? or Normal
Hi All
When I import an object into Cura 2.4 it is often not in the best orientation for printing. I use the rotate feature to turn it to a better orientation. The trouble I'm having, is that if I turn it in one axis, and then use the 'Layflat' button to be sure it is sitting flat on the buildplate, it is turned some random amount around the vertical axis. This is frustrating if I am trying to orient a part to another so they can share a support tower, or to make room for other objects. Is this normal behaviour?
Pete
