Seeing all UM printers use 2.85mm filament I don't think they will start to produce filaments of other sizes until they start selling printers that use 1.75mm.
UM have said in the passed that they won't rule out making a printer that uses 1.75mm, Maybe UM4? who knows. Things change and they may decide to just stick with 2.85. This would be a few years away I think anyway.
Did you use the UM PVA in the raise??
It probably prints like a dream in the UM3 because it has been finely tuned to work in the UM3 but you may find if it was used in the raise it wouldn't be as good.
There are a lot of other manufacturers that are now making dissolvable support filaments. I have heard some good reports from e3d scaffold but never tried it. Most companies give out samples so it may be a good option to try as many as you can.
UM filament won't fit in the Raise (1.75). I do have Scaffold and Edge coming as well as a sample if rigid ink (E3D doesn't have samples). Hopefully one will work. I don't really want to switch to ABS.
Labern 774
