OK, so further tests seem to favor faster travel speeds.
At first. I had it set to 100mm/s, and setting it to 150mm/s has improved things a bit.
Also, I found one of the belts to be loose, and a belt pulley not even tightened down. Woops! Will test further with increased travel speeds. I might even try a lower nozzle temp.
Seems like a faster travel speed means the filament doesn't have a chance to ooze out before it gets to the next spot.
Semus 0
