Posted (edited) · Top of Object Red in Object View
Hello, so I designed a spinner in blender and exported it, and when viewing it in cura the top of the object is red, and I was curious as to if this should be cause for alarm before sending it to my schools 3d printer.
I have made a few other spinners the same way in blender and they didn't have the red top.
Solid View
Any incite would be helpful.  Thanks!
    The modeler you used uses a different "winding order" for normals. So the part of Cura that visualises overhang actually thinks your model is inside-out, which makes causes overhang to be shown on top surfaces instead of bottom surfaces.
    http://cmichel.io/understanding-front-faces-winding-order-and-normals/
    CuraEngine (the part of Cura that does the slicing) does not use the normals of the geometry, so it is no problem for printing.
