UM3 extended no video
Cerguei
Posted · UM3 extended no video
Can you dump the logs to USB stick to analyze?
Use System -> Maintenance -> Diagnostics -> Dump logs to USB to make this happen.
Check for messages about the mjpg-streamer starting (or failing to start).
If this service cannot be started, we'd like to know.
    Hi Marco,
    Starting :
    Logs begin at Wed 2017-03-29 20:49:48 CEST, end at Sat 2017-04-01 14:34:42 CEST. --
    Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: starting application
    Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: MJPG Streamer Version.: 2.0
    Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: Using V4L2 device.: /dev/video0
    Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: Desired Resolution: 800 x 600
    Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: Frames Per Second.: not limited
    Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: Format............: JPEG
    Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: TV-Norm...........: DEFAULT
    Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: www-folder-path...: disabled
    Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: HTTP TCP port.....: 8080
    Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: username:password.: disabled
    Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: commands..........: enabled
    Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: starting input plugin input_uvc.so
    Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: starting output plugin: output_http.so (ID: 00)
    Jan 01 01:00:36 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: serving client: ::1
    Jan 01 01:01:13 ultimakersystem-ccbdd30015e6 connmand[198]: ntp: time slew +1491049219.905818 s
    Apr 01 14:21:32 ultimakersystem-ccbdd30015e6 systemd[1]: Time has been changed
    The line
    tells me that the streamer is listening to port 8080
    Can it be a router/switch/firewall that prevents you from connecting to port 8080?
    IF you can try to telnet to the machine on port 8080:
    telnet  8080
    it should return with
    Trying ...Connected to .Escape character is '^]'
    If it fails to connect:
    Trying ...telnet: Unable to connect to remote host: Connection refused
    In the latter case, something on you network is blocking access to port 8080 on the printer.
    Connecting to telnet OK :angry:
    The line
    telnet  8080
    Telnet ok, but streaming from api or Cura isn't working.
    That's really a strange one.
    Yes Marco, I really don't understand, don't work with two mac Cura 2.3 / 2.4 / 2.5 and app on iPhone. Perhaps cam HS...
    Thx for your help
    Can you send a full log?
    We'd like to see the kernel messages as well, maybe that will give us a hint of what's going wrong.
    Thanks in advance.
    Also, if you have just turned on your printer, is the stream accessible / working when using the API directly:
    http://:8080/?action=stream
    No stream with http://:8080/?action=stream, white page, no error.
    Where can I send you the log ?
    Thx
