Hi Marco,
Starting :
Logs begin at Wed 2017-03-29 20:49:48 CEST, end at Sat 2017-04-01 14:34:42 CEST. --
Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: starting application
Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: MJPG Streamer Version.: 2.0
Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: Using V4L2 device.: /dev/video0
Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: Desired Resolution: 800 x 600
Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: Frames Per Second.: not limited
Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: Format............: JPEG
Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: TV-Norm...........: DEFAULT
Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: www-folder-path...: disabled
Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: HTTP TCP port.....: 8080
Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: username:password.: disabled
Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: commands..........: enabled
Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: starting input plugin input_uvc.so
Jan 01 01:00:35 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: starting output plugin: output_http.so (ID: 00)
Jan 01 01:00:36 ultimakersystem-ccbdd30015e6 mjpg-streamer[241]: MJPG-streamer [241]: serving client: ::1
Jan 01 01:01:13 ultimakersystem-ccbdd30015e6 connmand[198]: ntp: time slew +1491049219.905818 s
Apr 01 14:21:32 ultimakersystem-ccbdd30015e6 systemd[1]: Time has been changed
Can you dump the logs to USB stick to analyze?
Use System -> Maintenance -> Diagnostics -> Dump logs to USB to make this happen.
Check for messages about the mjpg-streamer starting (or failing to start).
If this service cannot be started, we'd like to know.
Marco_TvM 34
