As such I could not really leave the machine unattended, at least not around the start of the print.
Its a good routine anyway.. you can save a lot of your time stopping bad prints before wasting alot of plastics.
even if i have a perfect gcode combined with my reasonable calibration it can happen that the first layer doesnt stick properly and everywhere or it is smushed a tad bit too hard it creates backpressure..
when we have automated bed leveling implemented in Ultimaker , then you can go and print on unattended machines
for the rods i have these:
http://www.thingiverse.com/thing:54075
nice and adjustable...
Daid 298
Small note, the extruder upgrade should fit fine, if you use the correct number of washers. Which is most likely why it didn't fit for you. I've installed the upgrade on a Rev1 machine (older then yours) and there it fits fine.
