Posted · Ultimaker 3 extended PVA not working
I'm new in 3d modeling. I just received my new printer and ready to test it.
Everything works well with core AA and PLA.
If I want to use the second core with PVA, so I select the extruder 2 at the right of CURA's window.
In printing over network, the printer will allways use Extruder 1 with PLA.
Am I missing something?
Thank you for the help
Cura 2.4 and Cura2.5 beta
Ultimaker firmware : 3.6.2
Windows 10 64bits
    and welcome to the forums!
    If you want to print with PVA and a BB core, you need to tell Cura which extruder to use for support material.
    5a333533aeba3_ScreenShot2017-04-07at15_03_28.thumb.png.ef85364445ac28c0d605280e4039fbed.png
    If by contrast you want to print with two AA cores, then check out the manual section about merging models.
    https://ultimaker.com/en/resources/35686-merging-and-grouping-models
