Easy way to add files
Tiger91
Posted · Easy way to add files
I'm not sure if it would be possible to change this forum, but other 3D printing forums allow you to upload pictures/files directly from your computer (below a certain file size).
It seems that it would make a lot of things easier if that was possible on this forum as well.
