I tend to believe warping is mainly an adhesion problem, and to lesser degree a settings issue. I've compared bed adhesion methods (here) and went for the best solution, all prints came out fine since (read for about a week since my test). For both ABS and PLA.
What do you use for adhesion? Bare Glass?
Thank you for your reply, your post was pretty informative. So far I've been using bare glass. I'm doing another print now where I've lowered the build plate to 55 degrees, put glue all over it. I also have the fan go to 100% on layer 2, and have a top/bottom thickness of 2mm in addition to the settings stated above. Here's where it's at now: http://imgur.com/a/q44Za
I really like your comparison but I'm not sure where I'd get 3D Lac here in America. Seems that regular old hair spray like got2be might work well too?
mhotze 7
