T-Glase Successful Settings
Posted · T-Glase Successful Settings
Hey There
I've been using Taulman T-Glase (from Matterhacker) exclusively for a while now and have had excellent results with many tens of prints using the following settings for the different nozzles:
UM2+
For all the below prints/nozzles:
- Bed is coated with that PVA glue that kids use. Wipe down after applying with warm et cloth so the layer is very thin. My T-Glase parts pop off with just a little pressure from a scraper. No broken glass etc so far...
- Bed heat is 50oC
0.25 Nozzle
Nozzle temp: 220oC
First layer height: 0.15mm
Layer height: 0.1mm
Print speed: 15mm/s
Travel speed: 15mm/s
Bottom layer speed: 10mm/s
Fans: Off
0.4 Nozzle
Nozzle temp: 215oC
First layer height: 0.2mm
Layer height: 0.2mm (or 0.1mm works fine)
Print speed: 20mm/s
Travel speed: 30mm/s
Fans: Off
0.6 Nozzle
Nozzle temp: 215oC
First layer height: 0.3mm
Layer height: 0.3mm (or 0.2mm works fine)
Print speed: 30mm/s
Travel speed: 50mm/s
Fans: Off
Not tried the big boy 0.8mm nozzle yet.
Hope this helps someone.
Cheers.
