the second print core labled "BB" is only to be used with PVA. If you want to print ABS you need to use an "AA" print core. You can either remove the PLA filament from the AA print core or swap the second BB print core with the third print core you have (AA).
The cube you see at the back of the print is the "prime tower". This is used for dual extrusion prints (like PLA/PVA or PLA/PLA or ABS/ABS) so the nozzles are filled properly with filament when they switch during a print.
I'd suggest to stick to the default profiles in Cura 2.5 for now. PVA is not easy to print with, but if you activate the prime tower, you should be fine:
Make sure that you select the correct materials in Cura when you prepare the object.
And check the manuals for ABS and the Ultimaker 3:
Nicolinux 288
https://ultimaker.com/en/resources/23099-unboxing
https://ultimaker.com/en/resources/22226-how-to-print-with-ultimaker-abs
