Layers not printing flat
Posted (edited) · Layers not printing flat
So I have been having a problem with my printer where the first two layers or so are almost perfect and then the layers start to get messed up and it even jams every time around the halfway mark of the 3rd layer and im not sure if it has to do with this weird layering issue.
Im also not sure how to upload a picture to this website since im still new but i can give all of the settings I use
PLA
layer height: .1mm
wall thickness: .8mm
top bottom thickness: 1mm
infill 25%
speed: 40mm/s
temp:225
bed temp: 50c
fan off
retract length:4.5mm
retract speed: 25mm/s
supports with infill density of 80%
no build plate adhesion
Also I dont think its the extruder being jammed because the first two layer are pretty good if not perfect and then as soon as it hits the third layer I start running into issues
If anyone can help me figure this out I would love to have this good to go but I have only been printing for a few days so Im relatively new and I maybe doing this all wrong. (wouldnt be surprised)
