Irregular Circles on UMO+
Posted · Irregular Circles on UMO+
Recently I've had quite a bit of trouble getting technical prints (especially very small ones with tight tolerances) to print right on my UMO+. It looks like my printer isn't printing circles right at all. As you can see, the tolerances here are off by about a millimeter. The irregular circles are very repeatable, too - the odd oval shape is the same through the part.
Even just looking at the part, it's obvious that it's not completely circular:
I've tried every suggestion I could find on 3DVerkstan, which helped the problem a bit, but it's still there and it's enough to keep very small parts from printing correctly.
I turned my acceleration down to 1800mm/s^2, and I printed the part pictured at 15mm/s just to make sure my speed wasn't a factor. My Ultimaker has an E3D V6 with a mount that holds it pretty tightly. I don't think that's likely to be the issue.
I might just want to order some new timing belts for the motors, but those seem pretty tight to me.
Any other suggestions?
        • 31 replies
        • 25 replies
