Posted · Extrusion line overstep values
Does anyone know what the extrusion line overstep values are for Cura?
I'm not sure if that is the correct nomenclature. What I am referring to is how far offset each extrusion line is from the one adjacent to it. I assume it is a ratio of the extrusion width and is probably one to one.
It would be great if this was adjustable.
    I don't know what that value is, but you can adjust the overlap with the Material -> Flow percentage. The distance between is set with the Quality -> Line Width.
    Thanks a lot DaHai8,
    I normally work with simplify and I actually didn't think to check what version of Cura the company I'm working for was using. It did not have the full compliment of settings. I've downloaded a different version and now I can control everything I need to.
