Monoprice printhead stuck and drip
D_Horizon
Posted (edited) · Monoprice printhead stuck and drip
Hi, i got the Monoprice 3D printer (15365) and having a lot of issues just from the start.
I have a problem while printing from Cura(2.5) through USB cable - the PrintHead stops at the corner of the build and stays there for several seconds dripping PLA, than makes another line and return to the same spot and drip again until its build up and makes the prindhead to stop.
    Posted · Monoprice printhead stuck and drip
    Try printing from SD Card to isolate if this is a USB communications problem, or something else.
    Also check the Layers view in Cura just to be sure there's no command to move the head, drip, print, move back and drip more ;)
