Thank you for your suggestions, it is slowly getting better.
I'm printing with 4 solid top layer and 20% infill. I tried 6 solid layers and even 100% infill it didn't make a difference
1) Tension and print head slop look very solid.
2) If I don't enable acceleration shouldn't it use the settings from Marlin? Those work fine with other slicers.
3) I normally print at 195 (colorFabb PLA/PHA), tried it with 210 but no difference.
4) This made a difference at 30% but still not perfect, will try even higher values.
5) I'll try this next
Thank god for per model settings I can try a few settings in one go
DaHai8 73
Some suggestions:
1) Check your belts for proper tension and the print head for slop.
2) Enable Acceleration and Jerk Control in Cura and try lower values for the corresponding settings (Top/Bottom). Note that the defaults in Cura may be much higher than your Delta as they are defaulted for Ultimaker printers. So you may have to adjust all of them.
3) Try printing hotter +5-10c as it may be the filament is sticking to the nozzle and getting pulled away from the walls.
4) Skin Overlap Percentage: try increasing this value
5) Disable Infill Before Walls: This might help the infill adhere and stay in place if its getting pulled away.
How may top layers are you printing?
And what is your infill percentage?
