Diamond Hotend, Duet Wifi, Mini Kossel, RepRap firmware
Seems Cura only really manages to print 2 colors.. it _does_ use more colors, but if you use more than 2 colors on 1 layer, it only goes to the Prime tower for 2 of the colors... meaning its causing a lot of.. muddle things in the print..
You need to set all 5 temperature settings pr filament the same (ie: 200c) or the printing process stops a lot.. say, if first layer was set to 205 instead of 200, it does wait for it to reach 205 whenever it changes to a new color.. even if it is in layer 20.
Waiting for temperature changes etc takes place at last position of the printed part, and not some logicial place like the wipe tower.
Some very, very slow moves takes place the first few layers from the printed parts to the wipe tower... I have not been able to figure out, where this very slow move speed comes from.. also not entirely sure why it makes these moves - it's not just slow movespeed for first layer
Edited by Guest It didn't like my lists with urls.
dintid 6
ou need to do several things: comment out M83 in config. Insert M82 in your start.gcode.
Sources
*Where I learned about dimensions to enter: http://forum.seemecnc.com/viewtopic.php?t=7924
*A blog-post I wrote about all of this (working on a new one) - https://betrue3d.dk/using-duet-with-cura-and-diamond-hotend-and-firmware-retract/
Problems so far (mains):
- Seems Cura only really manages to print 2 colors.. it _does_ use more colors, but if you use more than 2 colors on 1 layer, it only goes to the Prime tower for 2 of the colors... meaning its causing a lot of.. muddle things in the print..
- You need to set all 5 temperature settings pr filament the same (ie: 200c) or the printing process stops a lot.. say, if first layer was set to 205 instead of 200, it does wait for it to reach 205 whenever it changes to a new color.. even if it is in layer 20.
- Waiting for temperature changes etc takes place at last position of the printed part, and not some logicial place like the wipe tower.
- Some very, very slow moves takes place the first few layers from the printed parts to the wipe tower... I have not been able to figure out, where this very slow move speed comes from.. also not entirely sure why it makes these moves - it's not just slow movespeed for first layer
Edited by GuestIt didn't like my lists with urls.
