FormFutura- Glow in the dark Green.
kmanstudios 1,120
Sorry, but you have to be more specific as I just searched for that and found they offer that in ABS and PLA. After that I stopped looking.
It is the type of plastic that matters, not the brand...well, in this instance. You usually do need both as there are some new hybrids out there with interesting properties.
A example would be that Acetone dissolves ABS. Do not know what it would do to the bowden tube, but the question is the most fundamental for the people in the know about such things.
I can see something like this happening to a lot of people. So, I keep an eye on such posts to put in the brain attic for when I need it.
Another idea is this; have you tried to take off the bowden tube and just pull on it to free up the material inside?
Apologies for not being specific about the material. It is PLA Glow in the dark green.
I've tried to take off the bowden tube from the nozzle head, but I could only pull off a little bit of the material, then again it got stuck in the tube and thereafter i'm unable remove the material.
kmanstudios 1,120
Did you try to take the bowden tube off the feeder and then pull on the material? You may have to heat the nozzle to get it loosened enough to let go.
Other than that, I am not sure what would dissolve PLA.
- 1
Thank you for your response. I tried the same method as pulling the bowden tube off the feeder as I did it to the nozzle head, but the tube doesn't seem to come off. Is there a way to remove the tube off the feeder?
Thanks a lot! I removed the bowden tube off the feeder and i removed the material.
Once again thank you. You saved me a lot of time!
Cheers
Vik
kmanstudios 1,120
You are more than welcome, and I am glad it worked as I am not familiar with any of the machines other than the UM3X.
I am about to purchase that material... what happened? User error or another garbage filament that i/we should stay away from???
- 4 weeks later...
It's just the user error. But the filaments needs to stored in a cool and dry place in order to have a high quality prints.
kmanstudios 1,120
What type of material is it?
