Update Firmware and Cura - is the firmware already downloaded with Cura?
yvichrome
Posted · Update Firmware and Cura - is the firmware already downloaded with Cura?
When I update the Ultimaker 3 firmware via the menu: Settings -> Maintanance -> Firmware update - does it get the firmware via ínternet from a server or is it already stored with the last cura download somewhere on my computer?
(In the second case, the order of updating firmware and Cura would make a difference, wouldn't it? )
    Posted (edited) · Update Firmware and Cura - is the firmware already downloaded with Cura?
    It's bundled with Cura.
    um, NO, Bad Jaime,  for the UM2 that is true, for the UM3 it is downloaded from the internet!
    Settings -> Maintanance -> Firmware update will download a new firmware version from the internet.
    P.S: If you have no direct internet connection you can also use images on a usb drive you'll have to download them separately but they'd be visible in that menu as well so in that case only no download happens.
    Thanks -!
