Posted
(edited)
· Control the extruder by Gcode line by line
several vague questions here, I'm not sure what you are trying/want to do, perhaps you could try and explain that a bit better?
you ca send print jobs from Cura.
you can control the printer, printhead position, print jobs, case lighting, more etc. from the REST web API
the documentation for that is available on the printer by browsing to: /docs/api/
you can also enter developer mode(makes your printer extremely insecure, hidden in the diagnostics menu) and talk to the services directly via dbus once you log in via SSH.
you can give some of that a try by logging in as the ultimaker user, in that command shell you can at least send gcode to the motion controller directly.
I hope that helps, otherwise please try to be a bit more specific...
robinmdh 100
Edited by GuestLink to post
