[Cura 2.6.2][GNU LINUX][Solved] The settigs are not saved
elfran
Posted (edited) · [Cura 2.6.2][GNU LINUX][Solved] The settigs are not saved
Hi everyone! I'm recently download the Cura-2.6.2.AppImage for Linux S.O It's amazing! but... it cannot save the settings, when i close the program and re open it, seems like the first start always and i have to reconfigure all over again :(
Someone have that problem? any ideas how i can fix it?
Thakyou! :)
    Posted · [Cura 2.6.2][GNU LINUX][Solved] The settigs are not saved
    Thks nallath, i reviewed the logs and i found a problem with some permission, for some reason the cura folder in the .config/ was owned by the root user, a simple sudo chown -R solved the problem:)
    vamtastic check the folders owners if you are lucky that could be the problem also.
        • 56 replies
        • 30 replies
