Frame is UMO,
motherboard with lcd from UM2,
heated bed with lead screw from UM2,
igus rails and bearings on Z and XY axis,
aluminium XY carriage,
UM2 style print head with Olsson block dual extrusion.
I can't see anny jumper on motherboard, something is not right because with stock 200 steps the Z axis is doing around 1/4 of normal movement.
Edit. Found the jumper, it was open so in 1/8 step. Using prusa calculator for my acme srew with 2mm per rotation I get 800steps. It's correct for movement but when asking printer for a move from 200 to 0 it scream and not move.. Not sure is it related to hardware issue or too much acceleration for example.
neotko 1,418
Z microstepping is set by a switch (not firmware) so probably you have it at default (no switch) 1/8 microstepping
Also without knowing more about the mods is hard to guess
