As I mentioned earlier with Cura 15.xx both nozzles work as expected but from reading on these pages a slower speed is required for the PVA as to the PLA, Cura 15.xx doesn't seem to support.
Cura 2.6.x does but when I select Ultimaker 2 Dual there is no facility for reduced printing speed on the support nozzle so it just supports from extruder 1. Neither does Ultimaker 2+, Ultimaker 3 does but prints a second prime tower with extruder 1 instead of extruder 2 (under but default was Reprap so I changed this to Ultimaker 2 under the profile setting).
I'll upload a picture later today.
Labern 774
If you just added 2 Olsson blocks to a standard UM2 then your problem might be due to too much heat transfer from one nozzle to the next. This was one reason why UM did not progress with this option.
What are the issues you are having with PVA? pictures?
