If i open Cura it says that a file ( python35.dll) is missing.
Tiov
Posted · If i open Cura it says that a file ( python35.dll) is missing.
Hey guys!
I downloaded Cura and everything whas fine! But when i closed the program and than i tried to open Cura again. But than it said that there is a python35.dll file is missing over and over again...
Does someone know the problem?
Thank you
    • 3 years later...
    • 3 months later...
    Hello
    I had the same problem. The first time you open the program it works, but when you try to open it by clicking on the icon, it doesn't work. The solution I found is the following: Instead of opening Cura via the icon on the desktop, you search for Cura in the Windows search thing that you open with the Windows-button. When you click here on the Cura icon it does work. You can also drag the icon from here to your desktop to create a new icon. This one now does work and you can delete the old icon from the desktop.
